Pioneer 427 - What to connect to what?
Discussion in 'Plasma TVs Forum' started by Leigh_1973, Dec 31, 2006.
  1. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    My 427 arrives next week and i would like to get the optimum way of connecting my components, i have the following;
    Sky (not plus)
    Pioneer 5100H HD/DVD recorder
    xbox 360
    Ive already deteremined that the 360 is being connected by VGA so thats sorted.
    Currently my sky box plugs into the 5100 and then the 5100 connects to my Sony CRT via the only RGB scart (AV1) on the back of the TV. Now the TV and 5100 have i-link so id like to be able to use that and i ocassionally record programmes on Sky
    So do i go with the above method of connection? or do i take advantage of the fact that all 3 scart sockets on the rear of the TV are RGB and connect the Sky box to AV1 and the 5100 to AV2? Unfortunately the 5100 doesnt have component or anything like that (i thought it did :rolleyes: ) If i got his method i presume i will loose the ability to record from Sky?
    Thanks.
  2. chaparral
    chaparral
    Apr 8, 2006
    1,977
    Planet Earth
    +370
    Sky (not plus) = input1 RGB scart
    Pioneer 5100H HD/DVD recorder = input3 RGB scart
    xbox 360 = input 2 component
    Only scart inputs 1 & 3 support RGB...
    Scart input2 is shared with the component input..
    Xbox360 looks much better by HD component then VGA..
    Plus.....Why haven't you got a sky plus box for recording....(there only like £50 to buynow)
  3. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    LOL ive read lost of peoples view regarding xbox over which connection and it seems that VGA is sharper, so i went with that.
    Thanks for the other bits though.
  4. chaparral
    chaparral
    Apr 8, 2006
    1,977
    Planet Earth
    +370
    Use the setup i posted above..plus run a S-video cable and audio leads from your skybox to your pioneer 5100h for best PQ recording from sky.
    That's if your skybox has S-video out..
    As looking at the 5100h specs..there no RGB input
    http://www.pioneer.co.uk/uk/products/archive/DVR-5100H-S/index.html
    DVR-5100H-S specs
    Input 1 SCART (AV connector2)
    2 RCA (Audio/Video) (front: 1)
    2 S-Video (front: 1)
    Output 1 SCART (AV connector 1)
    RGB Output
    1 RCA (Audio/Video)
    1 S-Video
    Optical Digital Audio
    System Remote Control Terminal IN
