Pioneer 420 HD upgrade?
Discussion in 'Blu-ray & DVD Players & Recorders' started by JohnCCFC, Mar 25, 2005.
  1. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    418
    +10
    Hi, I've searched unsuccessfully for a thread.
    Does anyone know whether the hard disk can be upgraded/upsized?
  2. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    Generally speaking, all DVD/HDD recorders are permanently locked to use the size of disk in the specification. So if you put in a 160GB disk, even if it worked, you would still only be able to use 80GB.
    The only machines i've read about being upgraded are early Pace HD Freeview boxes.
  3. JethroUK
    JethroUK
    Dec 5, 2004
    1,144
    +34
    I've heard of lots of machines being upgraded
  4. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    If you can give types / links for info it will help JohnCCFC.
    However, it is possible someone has found a way if you can get a Pioneer ID disk or something. Have a look through this thread. You'll need to go some way..
    http://www.videohelp.com/forum/viewtopic.php?t=253998
  5. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    If you wanted a 160Gb you should have got the 720
  6. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    418
    +10
    hmmmm
