Pioneer 420 Hard drive NOISE issues!
Discussion in 'Blu-ray & DVD Players & Recorders' started by thesnowman, Dec 10, 2004.
  1. thesnowman
    thesnowman
    Nov 14, 2003
    271
    +8
    Just got this dvd/hdd recorder a couple of days ago
    I got to says its a really great system except for the annoying load high pitch buzzing/whirring sound that the hard drive makes
    Has anyone upgraded there hard drive for this recorder for a better(quieter) one, I remember reading somewhere here a while back that its impossible to upgrade to a higher gb than the 80gb limit the pioneer 420 offers
    but is it possible to install a better/quieter 80gb hard drive, if so is it a simple case of plug and play or would there need to be any additional tweaking required.
  2. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    If it's that noisy it doesn't seem right. I can just hear a 420 about 3m away in a quiet room - fairly low pitched whirr. It's about the same as a Sony VCR playing.
  3. thesnowman
    thesnowman
    Nov 14, 2003
    271
    +8
    Believe me the noise is pretty loud, not only is it distracting but it gives me a headache.
    so anybody else, have you installed a new hard drive into the 420, any problems setting it up.
  4. akpak
    akpak
    Aug 24, 2004
    71
    Lincs
    I'd agree with Eddyad on this - my 420 is pretty quiet, so it sounds like a possible fault.
    Since DIY surgery will void the warranty, I doubt you'll find anyone who has done this yet - and I'm quite surprised that you're contemplating it. Surely with a machine this new you have some redress with the retailer, or Pioneer themselves?
    I was uncertain about one or two features on mine when I first got it, and when I rang Pioneer they told me they were very proud of their machines and would work with me and the retailer to make sure I was completely satisfied - though in my case after asking about these features on here I decided there wasn't a problem after all.
  5. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    As you've only had it a few days, I'd say an immediate replacement by your dealer is warranted. The dealer (you didn't say where you got it) shouldn't object after such a short time.
