Pioneer 3100
Discussion in 'Blu-ray & DVD Players & Recorders' started by Stereo Steve, Nov 26, 2003.
  1. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    Help, I'm a DVD-R div. Does my head in just thinking about it but we have loads of stuff on the Sky + HDD that my lady wants to commit to some kind of media and VHS is naff.
    So, is the 3100 a suitable machine? Will it record films from Sky Movies in full 5.1 (if so broadcast)? If not, which recorder will?
    What does it all mean? Can I use DVD-RW with this machine and then do sophisticated removal of adverts on my PC at a later date?
    ARGGGHHHHH
  2. pd45
    pd45
    So, is the 3100 a suitable machine? Yes
    Will it record films from Sky Movies in full 5.1? No
    If not, which recorder will? None
    Can I use DVD-RW with this machine and then do sophisticated removal of adverts on my PC at a later date? Yes
    ARGGGHHHHH [/B][/QUOTE]
  3. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    Thanks. So, no way of recording DD or DTS onto disks? That sucks but I guess I'll have to take the plunge anyway.
    Cheers.
  4. pd45
    pd45
    I am afraid not mate - at the moment anyway - I do believe that there are recorders in the pipeline for next year that will record the DD signal - maybe someone who knows can let you know the details.
    Regards
  5. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    Hmmm. I may hold off for a bit then or try to get hold of a super cheap recorder. Is -RW a good solution? In terms of PC editing, I guess you need a DVD burner in your PC and some suitable software. Do you have any idea which software so I can have a look at the options?
    Cheers.
  6. pd45
    pd45
  7. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    Cool, thanks for the advice. Appreciated. I may just get one (seen them for £366) and then flog it next year once the 5.1 models come out.
  8. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    Actually, looking at that, I may go for the E50 as it's only £250 and I could edit and back up all the stuff to DVD-R on the PC. Have to study the sticky thread a bit more first to see what's involved.
    I would look to replace the player if I could get 5.1 later on so I just need a cheap, stop-gap to get all the stuff off my Sky+ hard drive.
    Yep, think that's what I'll do.
    Thanks for the links and advice again.
