Pioneer 301 Sub Woofer?
Discussion in 'AV Receivers & Amplifiers' started by StevieC, Jun 3, 2005.
Tags:
  1. StevieC
    StevieC
    I have purchased the Pioneer 301 to go with my Toshiba RX34 DVD Recorder but have discovered that the sub-woofer on the Sony speaker system from my now obsolete DAV500 home cinema system doesn't seem to work.
    Reading through the manuals it seems that I need a seperately powered sub-woofer with a line in phone connection? Is this the case and if so what sort of unit should I be looking at (cheap as chips budget end)?
