Pioneer 220s
Discussion in 'Blu-ray & DVD Players & Recorders' started by berliner, Nov 10, 2004.
  1. berliner
    berliner
    Just got a pioneer 220s dvd recorder, well worth it, but when using it in tv mode/monitor mode it does not allow the teletext information to be decoded, it is ok when a satellite receiver is looped through AV2 aand the pioneer is switched off. If it is not recieving the teletext info how can i be sure that the PDC/VPS timer is working.
    Anyone else have this problem.
  2. PhilipL
    PhilipL
    Jan 18, 2002
    3,845
    103
    +444
    The DVD Recorder stips off the teletext information, the likely reason is that it is difficult to encode and would detract from the quality of picture.
    You should have a PDC/VPS indicator on the deck (possibly not on these models not sure).
    If you set a PDC timer recording and it records, then it is working. To be really sure, set the clock to manual and stick it 30 minutes out say, a PDC recording will still record at the correct (real) time.
    Regards
    Philip
  3. berliner
    berliner
    thanks for that it makes sense, as when i set it up for automatic clock time from bbc1 it got the time from the teletext info, not tried a VPS/PDC recording yet as only BBC1, itv and channel 5 seem to register as broadcasting VPS/PDC information on a thomson video recorder which i have.
    Could possibly try it on a european satellite channel as most of the german ones broadcast VPS/PDC obviously would need to change the recorders clock to CET.
