Pioneer 220 connected to PC
Discussion in 'Blu-ray & DVD Players & Recorders' started by loxley80, Jan 15, 2005.
  1. loxley80
    loxley80
    Hi all
    I've recently bought a Pioneer 220 (and been extremely pleased with it!!) and now want to connect it to my computer so i can use it to record onto DVD (my PC doesn't have a DVD writer).
    If there are any 220 owners out there i would like to find out whether this is possible and what lead/software i need to get to acheive this.
    My PC has USB and firewire sockets.
    Hope someone can help me!!!
  2. PhilipL
    PhilipL
    Jan 18, 2002
    3,839
    103
    +442
    You can not connect the Pioneer 220 to a computer, it has no Firewire connection for a digital output or input (the 320 model does but even then you need Firewire and not USB). Even if you could connect it is doesn't become a DVD Writer.
    If you need a DVD Writer your only option is to purchase one as you can't use a DVD Recorder as a DVD Writer in your computer.
    Regards
    Philip
  3. mattross
    mattross
    Oct 23, 2004
    265
    +7
    U could always the use Svideo in/out and audio in/out connections on your 220 to connect to a PC. My graphics card has a TV out Svideo I could use to record to DVD, and I have just bought a Pinnacle Freeview/analog TV tuner that has Svideo in if I wanted to record DVDs on the PC.
  4. clawson
    clawson
    As you can buy a DVD-ROM drive for about £15 (or a DVD writer for £30+) - which is probably no more than the cost of a decent interconnect cable - is it not 100% easier just to fit a DVD drive to the PC??
    (go to www.ebuyer.com for the best prices on DVD drives)
    Cliff
  5. mattross
    mattross
    Oct 23, 2004
    265
    +7
    Yes I would agree. U can get a Pinnacle TV PCI card with Freeview/analog tuner built-in for about £50 [oem version]. I just bought one, haven't tried it yet though.
