Pioneer 2011 Help ??
Discussion in 'AV Receivers & Amplifiers' started by darren7, Jun 25, 2003.
Tags:
  1. darren7
    darren7
    Re: pioneer 2011
    Hi this amp is cuttting out after 5 mins, not even running it that high, I have the correct 8 ohm speakers as well. it does not even get that hot, just goes onto standby.... any idears anyone had this do this.. speaker wires are not toutching or anything.
    Advise please
    Is it a back it?
    Darren
  2. jhjerpe
    jhjerpe
    Mar 1, 2003
    700
    2
    28
    North London
    +58
    I had a similare problem.... and thought I was going to have to send it back. As one last try I disconnected everything and went through a process of elimination.. wierd thing is when I connected everything back up it was fine!
  3. darren7
    darren7
    I have tried that still the same, I thought loads of people had these amps, and may have come across this?????
    not many repies
    D
  4. Daneel
    Daneel
    Dec 5, 2002
    2,843
    68
    London
    +8
    I haven't seen a single person in this country have shut down problems with this amp. I think I've seen 3 in the US but only with 4 Ohm speakers and at very high volume.
    Attach you speakers 1 at a time to see if there is a problem with a particualr speaker or amplification channel.
  5. Dazed
    Dazed
    sorry Darren FWIW mine is running just fine. You must be jinxed
  6. juboy
    juboy
    Mine's fine too. I'm using banana plugs at the amp and speaker ends, which I soldered myself to ensure they were done correctly.
    My speakers are 6ohm and 8ohm designs so I run the 2011 in 6ohm mode. It's never had any problems, although I don't listen to it particular loud I guess.
    I did hear that the very early UK 2011s may have had the same problem with early cut-out that plagued the US version... maybe you got one of these units?
