Pioneer 2011 Corrupting Component Signal
Discussion in 'AV Receivers & Amplifiers' started by meep, Feb 24, 2003.
Tags:
  1. meep
    meep
    Apr 22, 2002
    607
    Ireland
    +48
    Hi All,
    When I run the component output from my Sky Digibox (via RGB-Component convertor) through my Pioneer 2011 and into my HTPC (via Holo3D card), I get an unusable signal (very very dark)
    However if I run the component cable from the digibox directly to the H3D card, I get a clean usable picture.
    Anyone any idea what the receiver might be doing to my component signal and any ideas on a fix?
    Peter
  2. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    I'm no expert on component ... but if you have another component device (i.e. a DVD player) do you get the same results via the Amp and direct ... and if so, do you still get the same results if you use the component inputs on the amp that the Sky box was using??
  3. meep
    meep
    Apr 22, 2002
    607
    Ireland
    +48
    Sounddog,
    Thanks for that.
    That's part of my problem - no other component source at present.
    Posted this in the hope that someone would have come across similar before.
    I'll try to get a component DVD and some decent cables and try again.
    Regards
    Peter
  4. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    Okay ... I assume you have 2 sets of component cables (1 for Sky - Amp, other for Amp - HTPC) have you tried both of them and get the same results?
