Quantcast
Pioneer 2011/AX3/AX5 THX Query
Buckster
I have a Pioneer 2011 - quick simple question - but I'm not sure of the answer !
If you set to THX Cinema mode when watching a film - does it alter the Speaker setup to the Standard THX settings (ie, small for all speakers, crossover set to 80 Hz) or does it keep whatever settings you have set for your speakers ?
Thanks,
Mark.
RAL 12
No - the speaker sizes remain at whatever they were set to in the speaker set up menu and the crossover setting remains unchanged.
I pondered this same question when I got my 2011 - I wondered whether there was any way of having all speakers set to small for movie viewing and having the speakers as large for music replay. The only way is to manually change them in the speaker set up menu.
Buckster
Superb - thanks for the answer Ral 12.
Mark.
