paulefox
I have purchased a 2011 and I am running it with celestion a series speakers they are all 4ohm except the centre which is 6ohm
I have now found through the forums that I should be rumnning 8ohm with this amp
Will it effect the equipment if I use the 4ohm ones and also will I lose any quality.
To me it sounds really good.
If these are not suitable I was thinking about getting the B & W VM1 s
