Pioneer 100Hz Crossover
Discussion in 'AV Receivers & Amplifiers' started by NEW50M, May 2, 2005.
Tags:
  1. NEW50M
    NEW50M
    Can anyone help
    I have just bought KEF Eggs and 250W sub & Pioneer VSX814 Amp. I am a little confused as I can only set the crossover on the Pioneer to 100Hz when I understand that the Eggs would be better with this set at 80Hz.
    Is there anything I can do with the setting on the amp or sub to change this, or is that my lot. Any ideas?????
    Ta.
  2. wookie
    wookie
    Your speakers may integrate better with the sub @ 100Hz anyway as they "roll off" at 80Hz.
    So don't worry about it.....
    Set subs crossover to max or bypass.
  3. NEW50M
    NEW50M
    I have set the subs crossover to maximum, does sound better, I'll have to play about with the position and settings its now a bit boomy (if there is such a word)
    Thank again
