Pionee DV-444
Discussion in 'Blu-ray & DVD Players & Recorders' started by CMM, Apr 15, 2002.
  1. CMM
    CMM
    Mar 27, 2002
    15
    Does anyone no if the DV-444 will play RCE encoded discs when a mod from mailuk is inserted
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    I bought mine MR (flash upgraded) from Hifibitz, and has so far played everything i have thrown at it, suggest you get a flash mod, no hacks or anything just put the disc in and away you go, hope this helps.:p :p :p
  3. John Jennings
    John Jennings
    Aug 7, 2001
    282
    Uppsala, Sweden
    +5
    Entirely depends on the mod that that company uses. If it allows you to manually select the region as well as having the option to auto-region select then you should be okay. Simplest solution is to ask them!
  4. mcmullanbrush
    mcmullanbrush
    Apr 20, 2002
    1,137
    39
    rotherham
    i also have a pioneer 444 from mail uk who assure me it is rce compatable. so far i have not tested this as i cant remember which of my dvds are rce. one problem i have experienced though is with the region 2 one sided version of starship troopers which freezes at the layer change every time. has anyone else had this problem and if so is it the disc, the player or the combination of both
