Pio XDE- NO audio using component
Discussion in 'Plasma TVs Forum' started by bingle, Jan 27, 2005.
  1. bingle
    bingle
    Hi there, after trying everything I thought I'd ask the pros!! I watch DVDs on my Pio 435XDE via component. This is all fine- and the picture is great, however I can't get any sound at all. I'm using a decent quality fully pinned scart to carry the audio from the DVD player (Dennon2800mk2) to the media box (input2), but still nothing. As soon as I switch the feed in the options away from 'component' to scart...then bingo....I have sound, but I am of course taking picture from the scart lead, which is far less superior. Please Help!!! Thanks,
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +795
    Well component is a video only connection, what are you using to hook up the audio?
  3. moopa
    moopa
    bingle from another post I found the soloution as I too wanted to do the same.
    Simply get a scart adapter such as the one on an Xbox and stick the audio rca's into the back of it. Now stick this into the scart input of input 2... Hey presto! audio.
    Dave
  4. bingle
    bingle
    I'm using a scart lead to carry the audio, though it doesn't seem to work. It isn't a problem with the cable because the sound works fine when scart is selected under options.
  5. bingle
    bingle
    Hi moopa, I have tried that but still nothing- surely if that works, using a scart should work too. It says in the manual to just plug a scart into Input2 if ur using component,and the audio should flow!!! I don't know if it matters that I'm NOT using the POINEER speakers but am feeding the audio out of the media box to an old HIFI via monitor out. I get sound from all other inputs.Cheers.
  6. moopa
    moopa
    Hmmm that is strange. In my case I am doing the following.
    Xbox using HD component pack. Component input for video and then the scart input below input one for audio using the xbox scart adapter (The svideo and audio L-R) on it.
    I then select component from the input menu and the sound plays back fine.
    Sorry I couldnt be of any more help!
    Dave
  7. nujjy
    nujjy
    May 26, 2004
    228
    +9
    Please note that the left and right audio plugs must be plugged in the Input 3 Scart (not Input 2). Then select Component in the menu, and all should be fine.
  8. reckless
    reckless
    Dec 21, 2003
    987
    28
    +30
    I think that's on the 434, not the 435 as they changed it over. On the 434 I think you lost one RGB scart if you used component but they changed this on the 435. The first and third scarts are RGB, the second is s-vid/component.
    Again, I haven't tried this myself yet but I think it's correct.
  9. bingle
    bingle
    Thanks guys, will try all your suggests anyway....it's driving me mad!!
  10. moopa
    moopa
    I achieved this via input 2 scart and input 2 component at the same time.
    To alleviate any further confusion and to show how to do it please find an image of my own machine here:- (running audio as I took the pic)
    http://www.moopa.net/images/componetaudio.jpg
    Dave
