Pio VSXD812 set up
Discussion in 'AV Receivers & Amplifiers' started by harveydean_uk, Nov 26, 2003.
  1. harveydean_uk
    harveydean_uk
    Using a NAD319 to drive front two Tannoy R3 speakers and and Pio VSXD812 to drive Tannoy Centre and Tannoy R1's as surround. No Subwoofer.
    Question: I have set the front speakers to Large on the PIO, what should the settings be for the centre and surrounds (Large or Small?). Also - if I don't have a Sub - do I need to be bothered with the Crossover settings?
    Regards
    Dean - Newbie!
  2. kenlong69
    kenlong69
    Oct 24, 2002
    508
    Doha
    +6
    Hey there!
    You should set the speaker settings to large as if you don't you'll be missing a lot of bass. No it shouldn't matter where the crossover is set if the spekaers are set to large.
    Hope that helps!
    Ken
