Pio PDP43MXE-1 Infra red probs (again)
Discussion in 'Plasma TVs' started by NaTT, Sep 12, 2005.
  1. NaTT
    NaTT
    May 27, 2003
    1,107
    +77
    screen as above doesn't repsond to the IR controller. It's been back under warranty before, they found a dry joint in the IR sensor and replaced it, but the fault has returned (it worked again after a while and now it's back to nothing).
    Could it be because I use a Pronto (albeit that once out of action, neither Pronto or original work)?
    Anyone knwo how to clear down the "IR buffer" or indeed if there is such a thing?
    Thanks,
