Pio MXE1 or Panny PHD7 ?
N
neonmod
Finally i have come to the conclusion that i am looking at purchasing the MXE1 or PHD7 and i have £2500.
I need Dvi, VGA , RGB and component connections only!
Which panel is the best of the two?
Are their any threads or reviews of these panels anywhere?
Will i get what i need for £2500?
Cheers! :smashin:
NM.
Pat Marcus
Established Member
Be warned the Pio will not do hdcp via its dvi socket. This means that you cannot plug a "home" DVD player with DVi output into the socket and get a picture. You will, on the other hand be able to plug a PC in. If you need this functionality, like I do, you will have to either wait for the fabled Aurora after-market card or buy the Panny. However, be advised that The Panny will not handle signals at 50hz, the apparent forthcoming standard for UK Hi DEF TV from Sky. If you want everything, look at the series 4 NECs and the forthcoming 40 series from Fujitsu (due out at the end of this month). You will find masses of info on this site about all such things.
hornydragon
The Panny cannot handle 720p or 1080i HDCP Digital but can on RGBHV
N
neonmod
Cheers Guys!
I found out these things over the last few days so i have decided to get the Pio 435XDE which seems to offer everything and more.
Comes on tuesday and have just got the wall mount!
Gonna be busy, Can't wait!
NM.
Amazon Fire TV Cube Gen 3 Review: Coming Soon
