Pio MR output Prob
Discussion in 'Plasma TVs' started by cashlessbond, Jun 3, 2005.
  1. cashlessbond
    cashlessbond
    Jan 1, 2005
    1,180
    Epsom, Surrey
    +45
    I hooked up my Recievers monitor out via S-vid to my Media recievers input 2 I also switched input 2 on the MR to S-vid but cannot get a picture of the setup menu. I have also hooked up my DVD player via S-vid to the MR input 2 and again no picture. Do you think that there is a fault with my MR's input 2 or am I missing something? (a Brain) :D any help out there :lease:
    PS if I plug the s-vid into the front input (4) of the MR it works fine.
  2. cashlessbond
    cashlessbond
    Jan 1, 2005
    1,180
    Epsom, Surrey
    +45
    Well surely someone must be able to give a bit of advice. Come on you av nuts, help us out. Anyone with a Pioneer 435/505XDE suffer with the same problem? :lease:
