Pio BDP-140 Initial Impressions
Discussion in 'Blu-ray & DVD Players & Recorders' started by daveymcd, Jan 11, 2012.
  1. daveymcd
    daveymcd
    Apr 19, 2006
    154
    With pretty much a straight from the box configuration, I'm a little disappointed with it. I know it's a budget player, but my other HD sources are an original Thomson SkyHD box and a nearly as old Toshiba HD-E1 HD DVD player. Unfortunately, at the moment these are giving me (subjectively) a better PQ
    My main PQ issues are:
    1. what looks like noise/processing artifacts in large areas of similar colour e.g clouds. (I don't get this with my other sources) resolved via TV/Player settings
    2. poor black level differentiation (again not an issue with my other sources)
    I have noise reduction set to zero - so that's an obvious candidate for change! What are the downsides to applying noise reduction?
    I've the color space set to YCbCr 4:4:4, as this is what my calibrated Sky box uses and seems to give more natural colors than 4:2:2. I don't think my display supports extended RGB.
    All other settings are at their defaults. Any suggestions as to how I can overcome the issues above?
    resolved :)
    Also, the current version of the euro firmware seems a little buggy:
    When browsing DLNA sources it confuses photos with videos
    It can hang when browsing a long file name
    Playing files it doesn't like can cause it to hang
    It won't send 1080p24 to my display although it accepts 1080p24 inputs
    and finally, to top it all off, the UK version doesn't contain the Netflix app.
  2. daveymcd
    daveymcd
    Apr 19, 2006
    154
    Any opinions? Send it back/spend more money?
  3. scottthehat
    scottthehat
    Jan 6, 2012
    11,160
    2
    167
    honiton
    +2,799
    has the player got any adjustment for brightness and things like that, find out if your tv will accept the rgb,
    i found that the toshibas i bought needed to be adjusted in there own menu and set the brightness down to -10 and it made a world of difference everything seem washed out elses and it picked up all the artefacts in the shadow areas. now the picture quality looks great.
  4. daveymcd
    daveymcd
    Apr 19, 2006
    154
    It does, although still haven't sorted the black issue, but artefacts are gone, solved as I discovered a "user" error in the TV settings (Pure Cinema set incorrectly).
