pio ax5 - pio 757 help needed
S
SirAdam00
I got yesterday my new AX5i and have an question regarding subwoofer connection.
Actually I don't have any active subwoofer so I disabled it in main SETUP but LFE indicator on AX5's display is flashing anyway. Why? :confused:
FYI I'm using iLINK for carring out audio from DVD source
/SirAdam00 :hiya:
Crustyloafer
That just indicates that the receiver is getting a 0.1 signal fro the subwoofer from the DVD that is being played. If you have told the reciver that there is no subwoofer then it will automaitcally redirect any LFE signals to the speakers that you have deignated as being 'Large' in your speaker configuration.
The Best Netflix Movies and TV Shows Coming in October 2020. Tom's Thumbs.
