Pio 868! Problem with HDMI
Discussion in 'Blu-ray & DVD Players & Recorders' started by kevtotty, Oct 10, 2004.
  1. kevtotty
    kevtotty
    Hi there
    My player will only hold the HDMI connection for a few minutes, as if it fails once it has warmed up.
    It's linked to a Pioneer 434.
    Subsequently I have had to resort to a crappy S video link. :rolleyes:
    Has anyone else experienced similar? or could offer any advice? :( :confused:
    Regards
    Kev
  2. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    New Zealand was Nottingham
    +86
    Yes :)
    My problem turned out to be a dogdey HDMI connection. have you tried un-plugging it and re-connecting?
    Also there is a frimware fix availible if this doesnt work out.
    Try the above and if it doesnt work out I will find you the firmware link :)
  3. eggybread
    eggybread
    Aug 7, 2004
    142
    On the subject of firmware fixes etc, for the pio 434 and also pio 868 etc...
    where the heck are these found and when does one know when one is available?
  4. banyantree
    banyantree
    Sep 8, 2004
    181
    singapore
    +10
    I had exactly the same problem with my HDMI connection and the same equipment. It would only hold the HDMi connection for several minutes before giving me interference.
    I thought it was the DVD player but it turned out to be the plasma receiver.
    There was a fault with the HDMi connection on the receiver.
    Pioneer replaced the receiver and brought around another DVD player to try that out too.
    good luck
  5. kevtotty
    kevtotty
    jack daws
    I have tried pluging & unplugging both ends many times.......
    Help!
  6. NC11
    NC11
    Sep 19, 2004
    465
    London
    +7
    this is obviouslly a fault with yr equipment , so the best thing to do is to call up yr supplier\pioneer. the sooner the better....
  7. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    Sequoia Technical Services
    County Estate, Nunn Brooke Road, Huthwaite, Sutton-in-Ashfield
    Nottinghamshire
    NG17 2HU
    0870 7778789
    TV/Q/DVD
    Contact these people (its where your equipment will get sent to). I think I dealt with guy called Stuart.
    Just give them a bell and they will sort out the rest :)
  8. rajpura
    rajpura
    i had a similar problem when i was using a chord hdmi cable, replaced it with a supra and ive had no problems since
  9. iceman1
    iceman1
    I am having the same issue, spoke to Pioneer and they had no idea what was going on. Do you know where I can get the firmware update?
  10. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    Yep, look at my last post ;)
    Just give them a call :)
  11. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    Ok, as so many people are having issues I have taken my player into Sequoia Technical Services for them to have a look at.
    Now I havent had a problem with mine player since I fiddled with the connections a couple of months ago. I thought I better do this a. Cos so many people have had snaggs and b. Whilst its still new (bought June).
    I will post here (hopefully tomorrow) when I find out what they think the propblem is. Pioneer say it a frimware fix, but we will see :)
  12. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    Let us know how you get on.
    Ta, M.J.
  13. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    Well I got call this afternoon (48 hours after drop off) to say that my machine is ready :smashin:
    Pioneer know of HDMI issues and it is just a firmware fix.
    Thanks to:
    Nottinghamshire
    NG17 2HU
    0870 7778789
    For a quick response. Also nice blokes too :)
  14. storole
    storole
    Would you please check what FW version you've got?!
    Do this:
    Open player menu
    goto Initial Settings
    goto Option (no enter to the list)
    press DISPLAY on remote
    and player display FW version.
    Please report back !!
  15. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    Will do but it will be later on, after I have watched 3 episodes of 24 :laugh:
  16. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    Heres what it says:
    "Region 2 / VER: 1.506(16)/ AV1: 20/28"
    I hope the region 2 bit doesnt mean my multi regions gone :eek:
  17. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    Do they also do SDI modifications to the 868?
  18. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    What is the firmware details for unaffected players?
  19. WarLock
    WarLock
    does someone know where to get the firmware updates for the 868 in portugal ?!
  20. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    MJ I havent a clue about your 2 questions. Give them a call they all seemed really nice people :)
  21. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    My firmware says : Region 2 / VER: 1.406
    The unit was manufactured in Mar 2004. Will it be one of the older units that has HDMi quirks and the Chroma Upsampling Error (C.U.E.)?
  22. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    Anyone?
  23. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    Yep you need the firmware upgrade :)
    My unit was made in May 04 not noticed the chroma bug. And I aint gonna look for it :nono: :laugh: :laugh:
  24. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    Hi, was you player still Multi-Region when it came back?
  25. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    Yep.
    And if it hadnt have been when it went in, it would have been when it came out. If you know what I mean ;)
  26. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    o.k. what do i do? who do i speak to?
    thanks.
  27. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    What manufacturing date (Jun 04 onwards?) would have the NEW firmware and NO chroma bug? Thanks, Martin.
  28. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    Nottinghamshire
    NG17 2HU
    0870 7778789
    TV/Q/DVD
  29. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    Dunno mate.
    Im getting one for a friend today and Im hopefull it will be upto date. I will check :)
  30. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,118
    Southampton
    +264
    My 868 was made in May 04 - it has the later firmware,so I dare say that was when they started running the newer firmware out.
    With regards the Region tag at the beginning of the firmware details - it will flag up the region for the last disc you played - i.e if your 868 is multiregion,and you play a R1 disc,then check your firmware revision - it flags up Region 1 :
    If you then play a R2 disc,stop it and again check your firmware details - you will notice it shows Region 2.
    HTH.
