Pio 6G "direct colour filter" prone to scratching?
Discussion in 'Plasma TVs' started by yellowpostit, Sep 5, 2005.
  1. yellowpostit
    yellowpostit
    Jun 27, 2005
    177
    19
    Nottingham
    I'm worried that the 436XDE is more likely to get scratched, now that Pio have replaced the glass in the 435's with this new "direct colour filter", which I assume is plastic.
    Anyone any thoughts?
  2. madshi
    madshi
    Jul 18, 2005
    1,145
    48
    Hamburg
    +62
    The 5G Pios already have the direct color filter! The 4G Pios didn't have it.
  3. yellowpostit
    yellowpostit
    Jun 27, 2005
    177
    19
    Nottingham
    Oh, I thought one of the differences between the 435 and the 436 was that the 435 had a glass front filter, whereas the 436 doesn't. Maybe I was wrong then.
    So if the 435 had already done away with glass, how did it stand up to scratching? Okay, I hope!
  4. PUD the Ancient
    PUD the Ancient
    Apr 25, 2003
    1,607
    notts
    +151
    I have not seen the 436 yet but I have seen a 435 on display in sevenoaks and it was severley scratched on the black surround. it did look like the plastic was prone to scratching a bit like the panasonic crt I have at the moment. It was a bit off putting as I am considering the 436 at the moment.
  5. yellowpostit
    yellowpostit
    Jun 27, 2005
    177
    19
    Nottingham
    paul - was it just the black surround, or was the actual screen scratched as well?
  6. tscotsman
    tscotsman
    Dec 29, 2004
    846
    +15
    Other thing to consider also is that with less glass it may be more noisy as stated in the 436XDE manual
  7. PUD the Ancient
    PUD the Ancient
    Apr 25, 2003
    1,607
    notts
    +151
    Not sure if the screen was scratched aswell as I did not really study it. It was just that the scratches on the surround really stood out. I will have a look next time I am in sevenoaks.
  8. yellowpostit
    yellowpostit
    Jun 27, 2005
    177
    19
    Nottingham
    Paul - see you are in notts. me too. would that be the sevenoaks on mansfield rd? i might pop in if it is
  9. PUD the Ancient
    PUD the Ancient
    Apr 25, 2003
    1,607
    notts
    +151
    Yes thats the one, also I think it may have been the 50" not the 43" but its stiil the same model just bigger.
  10. Cwhelan
    Cwhelan
    Jan 29, 2005
    140
    16
    Milton Keynes
    I've had a 505XDE for 9 months now & it still looks like new.
    Maybe it's because I have no Kids :thumbsup: or the fact that I clean it myself & don't let the wife or cleaner anywhere near it!! :eek:
    One big advantage over glass is the weight difference in the newer models. You don't need a re-inforced wall or floor to place it on!! :D
  11. SteveBradley
    SteveBradley
    Jan 6, 2005
    20
    Dubai
    The 435 definately has a plastic screen, I have had mine for 6 months and it looks brand new, likewise I don't let the wife, cleaner or anybody else anywhere near it, I clean it myself. My only scare has been the discovery of smudges on the screen, which were finally identified as "dog nose prints", easily removed but the hound is now in the dog house (literally!)
    Steve Bradley
  12. Rahmorak
    Rahmorak
    Nov 30, 2004
    450
    Lake District
    +10
    Care should be taken with cleaning/handling Plasmas whether or not it is plastic as there is a coating on the glass that can get damaged.
    Only use appproved products for cleaning.
  13. Drd
    Drd
    Jan 22, 2005
    1,811
    Approaching the doghouse at great speed
    +243
    3 kids,a mutt,a wife and an XDE.No problem (though I think the dog probably watches too much telly :D ).
  14. av_guy
    av_guy
    Apr 6, 2005
    25
    What cleaning products should be used? Any that Pioneer suggest/recommend? Something that will not scratch/damage the unit?
    The gloss black surround and screen have been cleaned with the silk cloth provided and it looks like new. The remainder of the unit has been cleaned with normal soft cloths.
    TIA
  15. Mep
    Mep
    Dec 25, 2004
    9,497
    +460
