Pio 575A No Dialogue via Scart Output
Discussion in 'Blu-ray & DVD Players & Recorders' started by macima, Dec 30, 2004.
  1. macima
    macima
    I've got a 575A hooked up to my Arcam AV50 via the 6 phono inputs. DD and TS output is fine thru the amp, however I'm not getting any dialogue from the TV's speakers when connected via the scart lead. It's as if the TV is only being sent the L/R channels from the 5.1 output. Has anyone else had this problem?
    Mark Mac
  2. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,449
    Yeovil
    +220
    Its common on quite a few dvd players. Basically when set to 5.1 output through its own decoder they don't downmix the sound on any connection even the stereo connections that are in addition to the 5.1 outputs and the scart audio connections. Maybe its a feature so you can use the tv's stereo speakers as the main front channels. You'll just have to toggle the downmix setting on and off as required.
