Pio 575a DVD -> Denon 3803 -> Panny 42" 5 series
Discussion in 'Cables & Switches' started by slyborg, Aug 11, 2004.
  1. slyborg
    slyborg
    Jun 16, 2003
    153
    +4
    Just got the DVD player and need another compnent cable, going to get a Belden one but was curious, I currently have a long Supra AV3 going from Plasma to the Denon and as I use the Denon to handle source switching I was going to run a short component cable from the DVD to the Denon.
    My questions are:
    If I'm going to get a Belden from DVD -> Amp is it worth upgrading the AV3 cable?
    Am I going to suffer any loss in quality by going via the Amp rather than from the DVD direct to the Plasma?
    I'm curious as to how noticable a difference there will be with the variety of routes and cabling options available to me, I'm no expert so unless there is likely to be a significant image imprvovement then to be honest I'm not likely to notice (begs the question why get a Belden but for the cost compared to some high street prices it's not really that much more)
    Si
  2. slyborg
    slyborg
    Jun 16, 2003
    153
    +4
    Bump, as a 12 foot replacement for the Supra AV3 isn't going to be cheap and I can't test it beforehand :-(
