TankTopLover
Just got this great player and wondered if someone can let me know what pic settings they have,its all on factory settings atm and looks a bit iffy.
I cant seem to find this option blacker than black? Will i have to update the firmware to get this option?rickardl said:Only 'blacker-than-black' turned on; keep rest unchanged to keep the picture
as unmodifided, "pure", nonbiased as possible before feeding it to your display.
I see,so which of these firmwares is the best? And do i just burn it do cd and pop it in the player? Thanks.flangemonkey said:This option is ONLY available in one of the third-party firmwares. Pioneer's own ROM doesn't for some reason support 0 IRE, and are set at 7.5 IRE by default. This will mean that certain tests like the drop-shadow on THX Optimode etc. won't show correctly.
In MTZ, Gufiak and Foncreator's f/w, there is an additional option called either "Blacker-than-Black" or "Black Level" in the menus. Turning these on will cause the player to pass 0 IRE...
PJTX100 said:Try Sharpness set to Fine and BNR On...PJ
Ify said:What does BNR stand for? What does it do, if it is turned on?
Just the fact that it takes away grain is why I don't use it.PJTX100 said:Block Noise Reduction, takes away grain but no loss of detail. I usually wouldn't touch such things with a barge pole, but this works amazingly well certainly on my projector and I've seen others comment it works on plasmas etc too with equal effect....PJ
