pio 575 for a 22 inch LCD ??
Discussion in 'Blu-ray & DVD Players & Recorders' started by farethewell, Feb 13, 2005.
  1. farethewell
    farethewell
    Guys, I need a piece of advice.. does it make sense to buy pio 575 and hook it up to my 22 inch LCD TV using SCART RGB? (tv doesn't have component input but there's a DVI) or should I go for a player with DVI/HDMI output (which is probably much more expensive)?
    I know there's Sammy HD-745 out there, but it seems hard to find and it's said to have some troubles with its stereo outputs as well as audio in SCART... please advise
    upd: other reqs are analog 5.1 output and divx support
  2. Dean
    Dean
    Jun 20, 2003
    2,890
    London
    +264
    I think the Pio would go well with the LCD, plus it has anlg 5.1 output and Divx etc.
