Pio 454/504 & freeview box
Discussion in 'Plasma TVs' started by dvdsubtitles, Jan 4, 2005.
  1. dvdsubtitles
    dvdsubtitles
    There seems to be a curious fault(?) with my Pioneer 504 TV.
    It has a Pioneer freeview receiver DBR-TF100GB connected to Input 1 via RGB scart.
    If I switch on the TV and the freeview box is already on, the TV immediately switches itself off again. To be more precise, the screen switches itself off, while the media box stays on and the media box LED flashes.
    I can only watch TV if I make sure the freeview box is OFF before I switch the TV on, and make sure that the freeview box is switched on AFTER the TV is switched on.
    Has anyone come across this?
    Cheers,
    Mat
  2. dvdsubtitles
    dvdsubtitles
    Haven't you other 434/504 owners come across this???
    The problem really shows up when I'm trying to copy old VHS tapes to my DVD recorder. I have to leave the TV on. If I switch off the screen while copying is in progress, I cannot turn it back on again without turning the DVD recorder off.
    Please help... Was this problem fixed with a media box upgrade?
    Mat
  3. dvdsubtitles
    dvdsubtitles
    anybody?
  4. jwramsay
    jwramsay
    Sep 7, 2004
    1,622
    West of Scotland
    +70
    I have a 434 and Pio Freeview box. I leave the Freeview box on (well the wife does) most of the time.
    However, I also have a Pio 220 DVD Recorder in the mix to complicate matters.
    I do NOT see the problem you describe.
    My wiring is :
    SCART1 Pio Freeview -> SCART2 Pio DVDR220.
    SCART1 Pio DVDR220 -> INPUT1 PDP-434HDE
    Everything is set RGB.
    n.b. SCART2 Pio Freeview only outputs composite and/or S-Video
  5. dvdsubtitles
    dvdsubtitles
    I have almost exactly the same setup you have. Only my DVD recorder is a different Pioneer model. I cannot remember which one.
    So far, the problem seems to occur with anything connected to INPUT1. I have tried:
    freeview -> DVD recorder -> screen
    freeview -> screen
    VHS video -> DVD recorder -> screen.
    in all cases, my screen cuts out if it is switched on if any of this equipment is already switched on.
    Had a thought, I should try it all with INPUT2 and see if I have the same problem.
    Mat
  6. jwramsay
    jwramsay
    Sep 7, 2004
    1,622
    West of Scotland
    +70
    INPUT2 is not RGB, use INPUT3.
  7. dvdsubtitles
    dvdsubtitles
    I'm already using INPUT3 with my 868avi DVD player via HDMI.
    Mat
  8. jwramsay
    jwramsay
    Sep 7, 2004
    1,622
    West of Scotland
    +70
    For test purposes then. (Jammy sod)
    It does sound like your MR box has a problem.
