PIO 436XDE speakers ?
Discussion in 'Plasma TVs' started by stevedster, Sep 11, 2005.
  1. stevedster
    stevedster
    Jan 13, 2005
    1,128
    48
    Birkenhead
    +41
    I have noticed that you can buy both an undermount (£200), and side speakers (£200) seperately so it will function like a normal t.v, will i need to get both of these or just say for example the side mount ones? let me know thanks. p.s i have a surround sound system linked to my dvd player, but dont really like watching normal tv through it, so thats why i need to know thanks.
  2. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    one or the other, its your choice :)
  3. yellowpostit
    yellowpostit
    Jun 27, 2005
    177
    19
    Nottingham
    Side or undermount, but not both
    cheers
  4. stevedster
    stevedster
    Jan 13, 2005
    1,128
    48
    Birkenhead
    +41
    cheers guys, hmmm tough choice, maybe the side ones i think. so with them at basically 200 and the desktop stand for another 200 is that like £2900 for the whole kit to work as a 'normal' tv ?
  5. tscotsman
    tscotsman
    Dec 29, 2004
    848
    +15
    yep thats why im not getting one and getting a pv500!
  6. yellowpostit
    yellowpostit
    Jun 27, 2005
    177
    19
    Nottingham
    If you don't want to use your surround speakers, then yes.
    Make sure your aerial is as good as it can be, though, unless you have Sky. I fear the screen won't be very forgiving of a poor reception. I've just spent £250 upgrading my aerial, ready for delivery of the 436 in the next couple of weeks, which is perhaps a bit OTT, but I've got full signal strength on every freeview channel now (or at least according to my current set top box). Before I upgraded, the aerial was rubbish - channel 4 was so pixelated it was unwatchable and bbc4 was non existent. But now the 436 should get a very good feed.
  7. Majid Khan
    Majid Khan
    Anyone know when Currys/Dixons or Comet are likely to be getting the Pioneer 436's in store ?
  8. av2diefor
    av2diefor
    The undermount speakers look great, no gaps, not available on the 506 though.
