Pio 436FDE inc Stand + Speakers : £2295 @ Richer Sounds
jwramsay
This seems a bit of a bargain, spotted on the Richer Sounds website.
Definately good JL pricematch fodder, as JL do sell the FDE, but not the XDE.
Damon
I was told the FDE was the XDE without the media box, what are the inputs on the FDE?
Did they have a speakerless option? Does anyone have a speakerless option.
And with no bracket or stand is there any option to stand this screen up on its own?
I would dearly love to save the extra £180 on this unit if there was a way to stand it up sans pedistal
Damon
jwramsay
Damon
You were told a pack of lies. FDE does have the Media box, but loses 1 HDMI and the VGA input. It also has fewer features than the XDE but I'd urge you to search for the other threads that go into detail.
You could lean it against the wall at an angle I suppose :devil:
As mentioned it comes with speakers and stand, you could always Ebay the stuff you don't want. (A wall bracket is 60 quid from RS100).
