Pio 436 SXE set-up.....Help Please
Discussion in 'Plasma TVs Forum' started by StevePn, Mar 12, 2006.
  1. StevePn
    StevePn
    Nov 15, 2004
    167
    Salisbury
    +5
    Expecting the new TV from Waitrose next week.
    :lease: could do with some help with connections etc.
    System as follows:
    Pioneer 436 SXE (stand mounted)
    Pioneer VSX-915-K (AV Receiver)
    Samsung HD-950 (DVD Player)
    Sky+
    Pioneer S-V410 H/C speaker set
    Also what picture settings should I use for the 1st 200 hrs.
    Many Thanks
    Steve
  2. xraystan
    xraystan
    This has been posted loads on here, take a look in the FAQ, it's helped me quite a bit.
    However here are the settings I'm using to run in my SXE
    Contrast -20
    Brightness - 0
    Colour - 10
    Sharpness - 3
    Everything else turned off that I can turn off, Purecinema, noise reduction, etc..,etc...
  3. Baz80
    Baz80
    Jun 23, 2004
    217
    Belfast
    +8
    Ive only had mine a week and i have turned everything down a little and put the tv in standard mode(full aspect), dynamic looks horrendous but i didnt turn anything off and i know its early days but my picture is great and there's no sign of any retention my plan is to knock all my settings up by one each week until im happy.:D
  4. Stilgar
    Stilgar
    Got my 436 RXE for about two weeks now and is has been running all that time on mostly default settings with most of the options turned on (PureCinema, DNR, ...) and contrast on 40. No image retention or screen burn so far, so you shouldn't worry too much about that.
    btw, try NOT using the big purple font for all your posts and try searching the forum before asking basic questions which have been asked a hundred times before. Keeps the forum more enjoyable and informative for everyone ;)
