Pio 436 SXE....... Hours menu, HELP PLEASE
Discussion in 'Plasma TVs Forum' started by StevePn, Mar 27, 2006.
  1. StevePn
    StevePn
    Nov 15, 2004
    167
    Salisbury
    +5
    Can anyone tell me where to find the HOURS menu on the PIONEER 436 SXE ?
    Steve
  2. Bacus
    Bacus
    Dec 30, 2004
    8,991
    Close to the sea
    +2,924
    should be the same as the XDE so use the search box on top of the screen !!
  3. jackal
    jackal
    Hi, I would really hesitate before entering the sevice menu of your screen. If you cause a problem, your warranty will be null and void.
  4. StevePn
    StevePn
    Nov 15, 2004
    167
    Salisbury
    +5
    SXE is different the XDE, so anyone with a SXE please could you help.
    Steve
  5. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
    Have you actually tried the actions suggested here for the XDE? They should work for the SXE
    Andy
  6. StevePn
    StevePn
    Nov 15, 2004
    167
    Salisbury
    +5
    BUT there is NO display button on the remote for the SXE.
    Steve
  7. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
  8. Bacus
    Bacus
    Dec 30, 2004
    8,991
    Close to the sea
    +2,924
    Thats probably cos it aint the display button !!!!!:nono: its the info button :laugh:
