PIO 436 screen is 625i output
L
lokomotive
Hi I hope someone know if the settings on the pio 436 are correct : it shows 625 when viewing certain channels and the screen goes black for a few seconds while adjusting the the settings full screen , anyway of switching this off? so much to learn as the setting and menu is quite complicate. Thanks for your help
cheers
L
lokomotive
Checked the nemu settings and it is set to Off. Will need to read through the manual again and see how to make sure everything is setup proprerly.
thanks for your help
Spudzz
It shows output number 625i on all of my viewing channels, is this the norm or what ??????
smiffy333
Guys this is normal, the pal standard is 625 intelaced lines but you only actually get 576 viewable lines as the remaining lines are for data info.
