Pio 435XDE cables
Discussion in 'Plasma TVs' started by Chuey, Dec 2, 2004.
  1. Chuey
    Chuey
    Nov 30, 2004
    24
    Does anyone know the length of the power cable and the cable between the media box and plasma for the Pio 435XDE? I am in the process of buying this plasma and will be putting the cables into the wall.
    Also, I read in the other thread that there are lip sync problems with Sky+ but there was mention that having an AV amp will resolve this problem. Is this the case and does the audio and video connections go directly into the amp first, then into the media box of the 435?
    Thanks.
  2. astirling
    astirling
    Oct 1, 2004
    800
    28
    Dunfermline
    +44
    Some amps have a delay option to correct lip sync issues. Can't help with the other stuff!
  3. Chuey
    Chuey
    Nov 30, 2004
    24
    Thanks.
    I will have a quick check of my AV manual. I have a Denon 3801. It's pretty old in AV terms, probably about 6 years old. Anyone out there with the same amp and know off by heart that there is the delay feature to resolve lip sync?
  4. bingle
    bingle
    i think the lead is 3m long not 100% sure tho.
  5. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    The power and link cables are 3m. Nothing special about the power cable, but shielded is good if you need it longer, especially if it's going in the wall with the video cable beside it.
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,268
    The Borders
    +2,572
    Chuey
    The supplied 'system' cable between the Media Box and the Screen is 3m and there is an optional 10m cable available from Pioneer UK.
    Best regards
    Joe
    PS 1 x IEC power cord to the screen + 1 x IEC Power cord to the Media Box.
  7. Tantalus
    Tantalus
    Aug 21, 2003
    289
    Aberdeen
    +3
    Unbeatable do this cable Pioneer 10m extension cable for 179.99.
  8. Chuey
    Chuey
    Nov 30, 2004
    24
    Thank you for all your responses. Now I can go away and start digging into the chimney breast. 3m is fine.
    Anyone out there with the Denon 3801 amp knows whether there is a delay feature? :)
