pio 435xde audio confusion
Discussion in 'Plasma TVs Forum' started by moopa, Jan 26, 2005.
  1. moopa
    moopa
    Is there anyway of routing audio through the media reciever when using the component input at the same time?
    Many thanks
    Dave
  2. reckless
    reckless
    Dec 21, 2003
    987
    28
    +30
    I've not done this myself but I raised a similar question as I was deliberating using the component in to connect my PS2. I believe the answer was that you need to take the audio leads to a a scart plug/connector and place that in scart input 2.
    Please note that I haven't tried this yet so have no idea if it will work. To make sure I haven't misquoted, do a search for it and you should find my post, it's less than a month old.
  3. moopa
    moopa
    reckless.
    Many thanks! This worked a treat! Someone else just asked the same on the forum. Hopefully your advice will work for them too.
    Dave
