Pio 435xde/868 configuration help?
Discussion in 'Blu-ray & DVD Players & Recorders' started by thillman, Dec 16, 2004.
  1. thillman
    thillman
    I have taken delivery of a 435xde and the 868 connected over HDMI outputing at 720p.
    Although great at first glance, the qulaity of the DVD image still have some artifacts and poor shading on faces etc.
    Does anyone have any tips or suggestions for fine tuning the setup?
  2. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Get yourself Avia or DVE to tune the display. An absolute must.
    Or just sit a bit further away :D
  3. thillman
    thillman
    Thanks - I will get DVE PAL...to be honest, the display is a bit too big for the room...
  4. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Trust me. It won't be for long. You'll soon get used to it and wish you'd bought the 504 :D
  5. Scarface12
    Scarface12
    what are an avia or dve?
  6. Niraj
    Niraj
    DVE
    AVIA
    You could also use the THX Optimiser that is part of a lot of the newer DVDs.
    Hope that helps.
    Niraj
  7. drago.d
    drago.d
    Apr 25, 2003
    172
    Kings Langley, Herts
    +9
  8. drago.d
    drago.d
    Apr 25, 2003
    172
    +9
  9. goatlips
    goatlips
    Nov 22, 2004
    272
    Croydon
    Yes it will get much better with time. I have had mine for nearly one year and it's spot on now!
  10. sanja
    sanja
    Ive had mine since friday and i can honestly say even without much tweaking the picture from freeview is gorgeous even sky is pretty damn good.Anyone rigged theres up to a panasonic S97 DVD player yet?Wonder if anyones got some settings when connected via HDMI. :hiya:
  11. thillman
    thillman
    I now have DVE - stupid question time....
    I can't see where on the DVD there is any help/guidance to balance the colour settings or the colour temp. There are settings and filters for three channel colour, but what about the cyan & magenta etc?
    Also, when using the colout filter to balance RG&B, I can't get the suggested result (ie, making the blue fit the blue background).
    And the last stupid question, any guidance from anyone on configuring the 435 for a Pioneer DVD HDMI connection - again, nothing on the disk for HDMI connections....
    ...or have I missed something on the disk?
    :lease:
  12. Xstyle
    Xstyle
    Sep 27, 2004
    3,496
    Berkshire
    +146
  13. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,117
    Southampton
    +262
    When we bought the 504,it looked huge - just checked out the Pio 61" 615 - it makes the 504 look like a portable TV you'd stick in the bedroom.
    The guy that owns the shop where we bought the 504,said he'd give us all our money back to go towards a 615.My missus was right up for it,but I however,found the 12 GRAND price tag a little off putting!!!! :rolleyes:
