Pio 435HDE grey dots, grain problem?
Discussion in 'Plasma TVs Forum' started by trueson65@mac.c, Dec 1, 2004.
  1. trueson65@mac.c
    trueson65@mac.c
    I got Pioneer 435HDE last week. I was getting troubled by gran and grey dots in porsion of picture when see sky or tv cable sources. How can I solve this ploblem or any setting you advise...
  2. trueson65@mac.c
    trueson65@mac.c
    Especially inside... postions of dark picture...
  3. jaguar
    jaguar
    Nov 17, 2004
    186
    I have the same set. I do not recognize your problem.
    Could you clarify what happens exactly? What are your settings?
    Is your cable signal OK? Just hook the Pio directly and solely to the cable wall outlet.
  4. JonStatt
    JonStatt
    Nov 18, 2004
    3,352
    103
    +445
    I think you are referring to the "dancing dots" that can be seen on a few plasmas during darker scenes or in darker areas of the picture.
    As far as I know, this is normal. I am unsure if this is noise or if this is the way that plasmas achieve darker shades. WHen you sit far enough away from the screen, you cannot see this at all.
    Jonathan
