pio 435hde dv575 connection
Discussion in 'Plasma TVs Forum' started by Leerock, Jan 4, 2005.
  1. Leerock
    Leerock
    Dec 26, 2004
    273
    19
    i ve got a pio 435hde plasma with scart,s-video,component,hdmi,vga inputs,
    a dv575 which has scart and component out
    and a dreambox sat receiver with scart out.
    I ve got the dvd player connected component to component.
    and the dreambox connected scart to scart.
    is there a better way to connect my devices?
    If i use the vga input of my plasma will i get better results?
  2. Leerock
    Leerock
    Dec 26, 2004
    273
    19
    Cmon
    Anyone.
    I ve found this product that converts component to vga.
    here
    will i have better results using this with my dvd player?
  3. Leerock
    Leerock
    Dec 26, 2004
    273
    19
    I feel no one is going to answer :boring:
  4. bobbypunk
    bobbypunk
    With your equipment you have connected correctly, if you want to improve the connections then you would need to upgrade the DVD to an HDMI equipped player to make use of the HDMI input other than that stick with what you've got.
  5. Leerock
    Leerock
    Dec 26, 2004
    273
    19
    ooohhh
    thanks a lot bobbypunk. :smashin:
    PQ is very good but I just wanted to know if i could improve it using different connections.
    Thanks a lot ;)
