pio 435fde 720 or 1080 HD ready??
Discussion in 'Plasma TVs Forum' started by birdseed, Apr 9, 2005.
  1. birdseed
    birdseed
    Nov 17, 2004
    229
    +5
    Dear all,
    Im looking to get a 435fde in the near future, i understand it claims to be HD ready, and sky HD will be 720i, which the pio will do. The euro1080i as it says in the name is 1080 so a greater resolution.
    Am i correct in thinking that the pio is only HD ready for the lower of the two HD resolutions and if in the future DVDs or sky goes for 1080, then my £2500 Plasma will be out of date??
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    pio FDE via HDMI input is ready for 720p @50/60Hz and 1080i @50/60Hz
  3. Ath3na
    Ath3na
    Dont get the FDE, if you have £2500 to spend now wait another month and get the XDE. If you check pricerunner.co.uk for the model number you will find the XDE as low as £2600.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    can also wait foir new Panny TH-42PV500 which will be FDE type price but better spec....
