Pio 435 Sky+ Remote Code
Discussion in 'Sky Digital TV Forum' started by markhawk, Mar 23, 2005.
  1. markhawk
    markhawk
    Mar 23, 2005
    Cupar, Fife
    Hi There.
    Just got this TV and cannot find a working code from the SKY interactive page to get my remote to work with the TV. Anybody out there help me?
    Cheers In Advance
    Mark Hawkins
  2. chillo
    chillo
    Sep 15, 2004
    767
    Northern Monkey!
    +34
    Yeah, i would be interested too for my pio434!
  3. Cynthia 7
    Cynthia 7
    Hi Guys,
    Have you tried the Sky codes from this site? Failing that, ring Sky customer services and they will give you loads of codes to try. It does take a lot of patience wading through those numbers. I should start with the Pioneer codes from the second table first. I hope you find the right one.
    http://www.satcure.co.uk/tech/digicode.htm
  4. markhawk
    markhawk
    Mar 23, 2005
    Cupar, Fife
    Thanks for that reply Cynthia. Managed to get it sorted using that link that you gave me......Much appreciated. If anyone else is interested, use the 4 digit code 0166, follow the instructions for entering the code on the link that Cynthia gave...........http://www.satcure.co.uk/tech/digicode.htm
    It won't work straight off but just keep pressing the TV button followed by standby until the TV turns off....Once it turns off press the select button and the LED should blink twice...Sorted. Haven't tested every function but i can now turn the TV to standby and adjust the volume using this code.
  5. diverse
    diverse
    Jan 21, 2004
    159
    16
    194 works on my 505XDE!
  6. Cynthia 7
    Cynthia 7
    Thanks markhawk for letting us know the outcome. It was interesting to know that you finally managed to programme the remote by keeping on pressing the TV button ........ A lot of people don't have the patience to do that. I managed to do that for a friend's old portable which didn't respond to any codes. It's a bit time consuming but wading through all the codes is worse!
    diverse, glad to know you found the code for your 505XDE.
