Pio 434HDE
Discussion in 'Plasma TVs Forum' started by Beefer, Dec 7, 2003.
Does you 434 Buzz?
Poll closed Dec 12, 2003.
  1. Yes
    5 vote(s)
    26.3%
  2. No
    6 vote(s)
    31.6%
  3. Yes but not intrusively
    8 vote(s)
    42.1%
  1. Beefer
    Beefer
    Aug 7, 2002
    52
    Gloucestershire
    Does your Pioneer 434HDE buzz?
    I would like to know this so as to confirm whether it is one off or a global issue before I contact Pioneer to see if they can do anything about it.
    Your help would be much appreciated.
  2. loonatic
    loonatic
    Jan 4, 2003
    1,877
    41
    Springwell Village, Gateshead
    +16
    Well I can't speak for the 434 but my old 433 used to buzz like mad from the top right corner. It was constantly present and got much worse when the panel was being driven hard with a very white/bright image.
    I think it's just how they are but I'll keep my eye on this poll as I was thinking about getting the 434 myself but it's begining to seem to me like it still has some of it's old faults.
    Have you noticed any streaking on your screen ? for example on the Aliens DVD when Ripley is standing in front of a monitor with scrolling green text, towards the beginning of the film, as the green text scrolls upwards you can see corresponding streaks running the whole width of the panel right through her face. Difficult to explain but very noticable. It's the other reason why I sent my 433HDE back.
    Cheers, Lee
  3. joys_R_us
    joys_R_us
    It does buzz a bit but hardly noticeable. The fan of the media box is more of a problem...
  4. Phil_Yeoman
    Phil_Yeoman
    Nov 17, 2002
    185
    Durham
    The 504 has a very faint buzz, nothing compared to the NEC or the fujitsu and certainly quiter than the panny
    Phil
  5. patmyhead
    patmyhead
    Feb 11, 2002
    588
    I o M
    Carnt here any buzz on the 504
    P@T
  6. Rexus
    Rexus
    There is a slight buzz from the panel but only if you're within a couple of feet - the media box fan is a bit noisy.
  7. lumpsucker
    lumpsucker
    Nov 18, 2002
    411
    Cornwall
    +15
    No buzz on my 504 panel or media box.
  8. Costas
    Costas
    Jan 14, 2003
    1,663
    63
    Swindon, UK
    +120
    My old 433 had a slight buzz that you can hear if you were going near the panel. My new 434 is buzzing slightly "louder". I can hear it at 1m distance. I contacted Pioneer and they insist it is normal. They said an issue would be if suddenly the sound level changes and it becomes seriously noticeable and stays at this level.
    Actually I was far more concerned with the new media box. I could here the fan at 3.3m easily. However when Pioneer changed it to follow up on the the dropout issue, the new box they gave me is extremely good. I have to go down to 50cm before I can hear the fan.
  9. StumpyBloke
    StumpyBloke
    Yip, mine buzzes
    Rich :hiya:
  10. Diapason
    Diapason
    Apr 29, 2003
    276
    Dublin
    +7
    It buzzes a little, and yes the media box fan is noisier, but to be honest, the sound of a DVD spinning in the drive beats both of them.
    Si
  11. Arsenal
    Arsenal
    Mar 25, 2002
    232
    London
    Yep.. well i dunno how good everyones hearing is, but i have to have my head around behind it and within about 2 feet to hear the buzz.. the media box fan is noisier, but no more so than my silver ps2 fan (i add the silver bit because it is 75% quieter than the original ps2).. and all of those are much quieter than any pc i turn on in the room.
  12. Billilu
    Billilu
    No buzz from the TV, no noise from the media box. I don't go looking for trouble so have no desire to stick my ear up close trying to find something wrong.
    The 434 is bloody great! Enjoy!
  13. Arshad
    Arshad
    Exactly
  14. gandley
    gandley
    Aug 31, 2003
    5,024
    Paradise Lost
    +269
    my old 503 made a slight hum when up close. this is NOT a fault infact some crts make a worse noise. its just the way plasma are. the 503 was noiser than my pany but turn the bleeding volume up and u dont hear anthing.
    as said get overit and enjoy
  15. Beefer
    Beefer
    Aug 7, 2002
    52
    Gloucestershire
    Thanks for your feadback guys,
    My Media Box does humm, probably more noticeable than the panel at certain times of the day. I have had the replacement box and makes no difference to noise levels. In fact while were on this note my Xbox (connected to Scart 3) makes it do the old drop out thing failry frequently, anybody else have this?
    I have been following your replies closely and mostly agree with your comments. However there are some people who claim that their plasma's do not make any noise - does this mean then that the rest of us have a problem?
    I realise that it isn't really a big deal and by no means detracts from a fantastic experience but is it not unreasonable to insist on one of these quiet versions?
  16. Brogan
    Brogan
    Oct 9, 2003
    7,476
    Cary, North Carolina
    +482
    My 504 screen buzzes from around the top but you have to be within 1 metre to hear it.
    The media box fan is barely noticeable.
    The Sky box is louder than both...
  17. howies
    howies
    same for me as brogan said. one of my cats has a louder purr than my screen:laugh:
