Pio 434...total audio drop-out!
Discussion in 'Plasma TVs Forum' started by drago.d, Dec 3, 2003.
  1. drago.d
    drago.d
    Apr 25, 2003
    172
    Kings Langley, Herts
    +9
    I've just installed the replacement media box (see my other thread for details) and not only has this not improved the issues re: picture quality, this box has absolutely no audio from the built-in tuner at all. :eek:
    There is no sound from either the plasma speakers or from the line out feeding the av amp.
    Audio from DVD and Sky+ via inputs 1&3 plays fine :confused:
    Am going back to dealer tomorrow to swap for media box #3!
    drago.d
  2. Diapason
    Diapason
    Apr 29, 2003
    276
    Dublin
    +7
    Don't!! Check out my response on another thread. You have to go into each channels settings and change the sound type manually. I don't remember the exact details, but I'll check it out and mail back better instructions if necessary. Let me know!
    Si
  3. drago.d
    drago.d
    Apr 25, 2003
    172
    +9
    Diapason,
    if you could find out how to do this I'd be very grateful.
    drago.d
  4. MTJ
    MTJ
    Sep 26, 2003
    38
    Hampshire
    drago.d,
    Diapson is correct this could well be due to not selecting UK in the initial setup routine for the tuner. The sound carrier frequency for the audio is offset from the main picture frequency. Around Europe the offset differs. If you don't tell the tuner you are in the UK it defaults (from memory) to Austria. They are the same as Germany and the carrier is 0.5 MHz different from the UK - hence no sound!
    The other way of checking this is that when you change channel the info banner will say Mono on every channel.
    You can fix by manually changing each channel to system 'I', or (my recomendation) by re-running auto installation and selecting UK.
    Hope this fixes it!
    Mark
  5. drago.d
    drago.d
    Apr 25, 2003
    172
    +9
    Diapason and MTJ,
    guys, thanks for the help there, all sorted :smashin:
    Perhaps the mains lead being a 2 pin (Euro) type should have made me think about what the default audio setting on the built-in tuner channels was likely to be :suicide:
    Still, only the pq to worry about now. (see other thread)
    drago.d
  6. Diapason
    Diapason
    Apr 29, 2003
    276
    Dublin
    +7
    No probs, glad you sorted one problem out anyway. Hope the rest gets sorted as easily!
    Si
