Pio 434 table top stand - how to losen suction cups?
Discussion in 'Home Cinema Buying & Building' started by Mics49, Mar 16, 2006.
  1. Mics49
    Mics49
    Jul 30, 2004
    958
    28
    +58
    I know it sounds stupid but when we last moved I couldn't for the live of it get the stand off the glas top of my AV stand. Those 4 suction cups created a vacuum that would most probably be sufficient for some Spidey action at the ceiling...
    Anyone having a good solution or own experience which does not involve destroying the cups and/or scratching the glass top to bits (i.e. no knife action)?
  2. DELUCAS
    DELUCAS
    Feb 11, 2004
    4,823
    KENT
    +951
    Try warming up the suction cups with a hair dryer ! If you can get to it !
    After all they are made of rubber and should expand and go soft !!
    Try at low setting if near glass!!! be carefull !!
  3. Mics49
    Mics49
    Jul 30, 2004
    958
    28
    +58
    That's not a bad idea. :D
    You wouldn't believe what I tried. Dental floss (in lack of thin cable)! And actually I managed two but that was that. Was also thinking of using a syringe and needle to pump air in - alas I ran out of them a while ago ... :D ;)
    Next time I'll give the hair dryer a try.
    Any others?
