Pio 434/Q-Sync active sinc extractor
Discussion in 'Plasma TVs Forum' started by SteveRSF, Aug 8, 2004.
  1. SteveRSF
    SteveRSF
    Nov 10, 2003
    270
    hi guys, i have the 434 up on the wall and up and running(will get pix up soon),but the picture from sky+ is a bit grainy.............so was told to get a q-sinc ,but i can't get a picture with it!
    will this work?....the only thing is it has to be connected to the pc port with is on the front of the media box! :confused:
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    No it won't work, who told you it would? You might just be already looking at the best that can be achieved with your screen.
  3. SteveRSF
    SteveRSF
    Nov 10, 2003
    270
    Thankx MAW!.......was told by local audio shop........... :mad:
    So thats it then no other gizmos?
    Are there plans for high def. form sky then?
  4. mikeycrawford
    mikeycrawford
    Nov 27, 2002
    116
    I'm going to go for a PDP-504HDE soon (saw it hooked up to SKY+ at my local dealer and even at 50" it looked good on most channels, even close up).
    One of the things I want to try is SKY+ through my HTPC/DScaler (that Logo killer is a handy filter) then into the VGA port on the Media Box. Will let you know how I get on and whether it makes a difference.
    Mike
  5. Stonedog
    Stonedog
    hi
    just put a PDP-504HDE up on the wall buried all the cables and i gotta say i am blown away by the PQ from Sky digi (gotta get rid of my Tivo tho as i find this had a major effect on the picture)
    Dvd's also look ace
    god... even the wifes happy :eek:
    cant believe how much of difference having a big screen on the wall has made to family life)...every nights a movie night!....ill even sit down and put up with Casualty on a saturday night now)))
    cant reccomend it enough :thumbsup: (or the KEF 5005 speaker set for that matter!)
    im chuffed)
    Mark
