Pio 434 Black Levels
Discussion in 'Plasma TVs Forum' started by KarlRobinson, Dec 1, 2003.
  1. KarlRobinson
    KarlRobinson
    Jan 8, 2002
    159
    16
    Bedford
    I was comparing my Sony CRT with the 434 today to calibrate the colour.
    The only real difference I found was the poor black levels.
    Is this normal? when you look at the CRT then to the Plasma, blacks look dark grey rather than black.
  2. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    Not on a panasonic plasma - its one of the key features of the panasonics over any other plasma.
  3. chez
    chez
    Feb 25, 2003
    1,630
    41
    Dallas, TX
    +19
    er, surely the 434 is a Pioneer rather than a Panasonic??
  4. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    er, think you missed the point of NeilMcRae's post there. :D
    :lesson: Panasonics display black as black, Pioneers display black as dark grey. A truism that was proved at The Event II where Pannys and Pios were sat next to each other; and even after ISF Calibration.
    StooMonster
  5. chez
    chez
    Feb 25, 2003
    1,630
    41
    Dallas, TX
    +19
    Okay, maybe but that's not what was asked in the original post!!
    KarlRobinson asked if that was normal for a 434. If you're saying that the black level of a 434 is not as good as a panny, then the answer to Karl's question is yes!
    Anyways - I'm sure somebody who has seen both (such as yourself Stoomonster) will confirm or deny this soon enough.
    Chez
  6. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    This is correct and normal for a Pioneer plasma. On one hand they are bright, on the other hand they have poor blacks; so much so that black looks more like dark grey as you describe.
    Panasonic screens, as a different example, have extremely dark blacks and excellent contract, but are not as bright.
    How's that for you chez ;)
    The ability to display black as black was one of the key drivers in my final decision of Pio-vs-Panny.
    StooMonster
  7. chez
    chez
    Feb 25, 2003
    1,630
    41
    Dallas, TX
    +19
    :smashin:
    I'm actually quite interested in this myself, so thanks Stoomonster :)
    I'm trying to decide whether to get a Panny 6 or Pio 434 - THe Panny 6's that I've seen seem to suffer flicker.
    I've only seen one 434 and that was in Currys, so not a good example!!
    Hoping to get a dem of the 434 this coming weekend (having trouble finding anywhere local that has both screens!)
  8. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    Not listing anything they both have and to compare like-with-like, so HD Panny (not SD) versus Pio looks something like the following*:
    Panasonic TH-42PHD6
    Pros
    Great contrast
    Black is black
    Geometry can be changed
    Many refresh rates
    Cons
    Flickers
    Rubbish internal progressive scan -- may need iScan Ultra or Lumagen
    Dimmer
    No third-party card support
    Pioneer PDP-434HDE
    Pros
    Doesn't flicker
    Good internal progressive scan
    Brighter
    Third-party card support -- like Key Digital PIO768P (one day)
    Cons
    Poor contrast
    Black is grey
    Geometry is fixed
    Fewer refresh rates
    *Apologies to all fans of either camp if any detail missed out, or detail is out of date.
    Most of these points could be clearly observed at The Event II where the 42" and 50" versions of these were side by side.
    StooMonster
  9. chez
    chez
    Feb 25, 2003
    1,630
    41
    Dallas, TX
    +19
    Thanks StooMonster - very useful information (certainly for things to look out for when auditioning!)
    I assume the SD Panny has the same pros/cons as the HD one??
  10. PhilCTTE
    PhilCTTE
    Aug 28, 2001
    1,689
    W.Mids
    +133
    I have the Panny 6 and there is no flicker. Maybe it was poorly installed where you saw this ?. I'm assumming static white text on a black background as per film credits etc, is where any flicker would be highlighted ? If this is the case then there is none .
  11. Cummo
    Cummo
    Jul 9, 2003
    27
    3
    Canberra, Australia
    I'm very susceptible to flicker which is why I have upgraded from the panny 5 SD to the 6 HD. In the brief time that i have owned it, I have only seen a very fine flicker with a white screen from a low definition input and when I have fed it with a 1080P signal @ 60hZ from a lumagen vision.
  12. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    I don't think my Panny5 50" flickers much, but some say 42"SD series 5 did. But series 6 appears flicker free (and this wasn't something that was visible at The Event II).
    So, strike flicker from the above.
    StooMonster
  13. KarlRobinson
    KarlRobinson
    Jan 8, 2002
    159
    16
    Bedford
    NeilMcRae
    I looked at the Panny next to the Pio and the blacks looked no different. On reflection I should of compared the two next to a CRT.
  14. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    well i owned both a panny pw5 and a 503hde and the blacks on the pio sucs.
    it tended to iluminate blacks and from my friends 434 the same is the case. my pw5 has better blacks(434 is a bit better than 503 to be fair)
    the pio however in a bright pic has a nice 3d feel to it but on poor source. oh dear
  15. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Stoomonster, I'd say the pio you refer to is a MXE? No card upgrades for HDE screens, and for me a major down side is the damn media box. But it's certainly true the blacks do not reach panasonic depths, whichever Pioneer screen you look at.
  16. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    Correct. Good job I had that disclaimer up there!
    StooMonster
  17. Costas
    Costas
    Jan 14, 2003
    1,663
    63
    Swindon, UK
    +120
    I question the poor contrast statement.
    Did you see such a thing? Just bear in mind that Panasonic measures contrast in a different way showing much higher ratios.
    I do not remember how they do it but I read somewhere the 434 has a higher contrast if they measured it the Panasonic way...
  18. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Contrast is too subjective to leave to numbers anyway, but you still have to decide whether it's black blacks, or good resolution, functional DVI, and total absence of flicker that is most important to you.
  19. RAMiAM
    RAMiAM
    May 24, 2002
    481
    UK, Kent (nr Ashford)
    +9
    I have a Pio and the black levels have never bothered me, to be honest I never notice it. In addition the colour range is better than the Panny and also the previous Panny models suffered on the inputs and DVI is still limited on the 50" models to a non-native res'.
    You should also note that in all fairness the Panny blacks are not as some say "blacks are black", they are just darker than the Pio.
    I think for true black you need a contrast of 15,000 or something insane. Far from what either panel can produce.
    RAMiAM
  20. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    yes true but the MXEs which u have were superior to the HDEs with better processing etc.
    nice car, very nice, luv the blue. marcos eh. a bit slow though. my yam R1 will show it clean heels. if u can see them in the distance that is. LOL(its not making up for somthing else is it........)
  21. Costas
    Costas
    Jan 14, 2003
    1,663
    63
    Swindon, UK
    +120
    gandley
    I do not know how the next version of the MXE will perform but the new 434/504 HDE seems to beat the current MXE. The new HDE have the MXE processing on board and have it improved further. My neighbour has the MXE and I had the 433HDE. You could see the difference then. Now I moved to the 434 and it is very hard to see a difference other than noticing the the 434 is a little better.
  22. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    I have put off plasma purchase for myself till I see the new MXE. Doesn't mean I'm set on buying one, but I've got to see it.
