Pio 433MXE owners
Discussion in 'Plasma TVs' started by LeonidS, May 11, 2003.
  1. LeonidS
    LeonidS
    Feb 11, 2002
    68
    Guildford
    could anybody use Pio 433MXE with default stand?
    How stable is it?
    I am planning to put it on 8MM glass.
  2. EffTee
    EffTee
    Jan 20, 2002
    196
    Bristol
    +5
    The feet that come with it are basic, but perfectly sturdy. There's no reason why they couldn't be used long term.
    EffTee
  3. LeonidS
    LeonidS
    Feb 11, 2002
    68
    Guildford
    According to the manual it should be screwed to the surface.
    If I put it on the glass surface obviously I cannot do this.
  4. zAndy1
    zAndy1
    Nov 26, 2002
    19,951
    2
    5
    163
    +7,069
    The standard feet are perfectly adequate and believe me if you put the display on a glass surface with the standard feet it ain't going anywhere! It sticks to the glass and won't move, mine doesn't anyway...
    Andy
  5. LeonidS
    LeonidS
    Feb 11, 2002
    68
    Guildford
    Could you tell me what is the size of this basic stand?
  6. philipb
    philipb
    Mar 6, 2002
    1,989
    63
    Swindon
    +132
    The supplied stand is actually two feet, each about 28cm front to back and a few cms wide. The screen slots into each foot and is then screwed to them. you have two possible fixing points for each foot, the widest ones being about 90 cm apart IIRC. you can fix the feet to the surface if you want.
    I don't use them now as I've hung it on the wall, but they work fine.
  7. MrAnderson69uk
    MrAnderson69uk
    May 12, 2003
    190
    +15
    Is there any reason to buy the Table-Top stand in addition to the panel from Empire Direct ?
    Does any one know if the panel from Empire Direct has a stand or two feet, as mentioned in this thread, included in the package ?
    I'll need to know soon as I might need to cancel the order for the stand !
  8. Dutch
    Dutch
    Dec 5, 2002
    2,598
    3
    North Yorkshire
    +282
    Hi Mr A,
    I believe the 2 feet come with the plasma as standard. The stand is an optional extra.
    Steve
  9. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,432
    The Borders
    +2,593
    LeonidS
    Unless you have mental kids or large pets then the PDK-TS01 is pretty sturdy - we've supplied lots of them and no mishaps so far in the last four years.
    I use one and its NOT screwed to any surface and the wee man uses the panel as a bit of a climbing frame when trying to retrieve his favourite DVD's from the shelves above it!!!
    If your worried you could always have your glass top drilled by a local glazer.
    Mr Anderson
    I'm sure the ED boys could tell you - but if they cant then rest assured you will have a set of feet in the accessories box that's packed at the rear of the display.
    Why buy the pedestal - you may want the extra height it gives you if you are sticking a centre channel speaker on the top shelf of your rack along with the plasma (I have my AG A'Diva sitting in front of the display and with the feet rather than the pedestal it would encroach on the picture area).
    Also with only the feet in place you have to ensure your video cables are flexible enough to turn at 90 degrees and make a decent connection and don't have too long a set of 'boots' so that your overstressing the cable and connectors.
    Otherwise the feet are a great no cost option.
    Best regards
    Joe
  10. MrAnderson69uk
    MrAnderson69uk
    May 12, 2003
    190
    +15
    Thanks Joe & Dutch,
    After reading this thread about the feet before I posted, and getting a negative reply from the guys at ED after I posted, who said it didn't come with a stand/set of feet, I cancelled that part of the order and was going to wait until the panel arrived.
    I later found on one of the Pioneer site that have the display spec. sheets that the package includes the feet. I was just worried that, like CRT's where the stand/cabinet is package in a separate box, that it's not always sold to you as you'd expect. They usually charge extra for the closed cabinet pictured on the manufacturers web site.
    I'll see how things go with the cables I get and maybe get a stand later.
