P
pedromartinez
Hope someone can help!
I have a Pio 433MXE with PDA5002 card fitted to which I have just hooked up a modded XBOX via the official MS Hi-Def Component pack via Input2.
The problem I am having is that when I set the xbox to output 480P (via MS Dashboard) when I restart the machine via the mod chip, the screen displays completley a grren hue similar to when tring to outpur RGB over component!
I assumed the 433MXE was capable of handling 480P?
Strange thing is, when I set the xbox to output 720P everything is fine & when I play 720P capable games the PQ is awesome & the display shows 750P.
The problem is, not many games capable with 720P but all supposedly will output 480P so could do with tring to fix the probelm is poss!
Any ideas?
thanks in advance
Any ideas?
thanks in advance
