P
pedromartinez
Hope you can help.
I am thinking of purchasing a Philips 963sa but before I do wanted to check out the Pal Prog issue.
From reading other threads it seems clear that with the remote hack, the 963sa will output PAL progressive. My question is, will a Pioneer 433 MXE with a 5002 card fitted, be capable of accepting and outputing PAL prog (presumably via component)?
Also, if yes, will the difference in PQ be worth the outlay?
Just wanted to clarify before spending the dosh!
cheers
cheers
