curty409
Hi guys,
newly joined on recommendation for some advice.
I've recently bought a Cambridge Audio A1 and also bought a pre-amp module to install internally on the amp.
After receiving the amp, I've noticed that the pins are missing from the section where the module is supposed to slot in.
The wires are not broken where the module fits, so doesn't look like it's had one in previously and removed.
My question is, can this be resolved easily, or will it be a bit off a ballache?
I will be able to return the amplifier if it's deemed as faulty, which I feel missing pins from the board would fall under that.
There are plenty of other A1s out there to buy, so not end of world, however wanted this sorted for Christmas, which is closing in very quickly!
Please also find an image of the amp board, with missing pins...
Appreciate any help and thanks!
- Curt
- Curt
