Pinnicle studio 9 problems
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by tee2, Jul 7, 2004.
  1. tee2
    tee2
    Mar 14, 2004
    14
    surrey
    Hi everyone, I have not been on the forum for a while but I will be back now on a regular basis.
    I have a Sony IP7 micro MV camera and have got Pinnicle studio 9 edit software.
    The problem is caturing film. When you press "start capture" it will play the film and the "captured" counter starts. When you go to edit you find out it has only captured about a min or so even though the capture counter in the capture screen said that there was alot more.
    I have tried to capure smaller portions at a time but some parts of the footage just will not record.
    Is this something I am doing wrong?
    I would be grateful for any help
    thanks in advance
    Tee
  2. cdb
    cdb
    Mar 1, 2003
    475
    28
    +47
    There's a big update for this from Pinnacle. Have you downloaded it to see if it fixes your problem?
  3. tee2
    tee2
    Mar 14, 2004
    14
    surrey
    Cheers mate
    That exactly what I did last night and it seem to have sorted it.
    Thanks for the reply anyway.
    T
