Pinnacle Studio
Discussion in 'Photography Forums' started by Techno Freak, Jan 18, 2005.
  1. Techno Freak
    Techno Freak
    Aug 24, 2003
    312
    16
    North-East
    Hello,
    The computer I have just ordered comes bundled with Pinnacle studio SE.
    For an extra £20 you can upgrade to the " full version ".
    Does anyone know the difference between the full version and the SE version?
    Is it worth shelling out the extra?
    Thanks.
  2. Roy Mallard
    Roy Mallard
    You can alter colour and contrast on the timeline, not just on capture, you can seperate audio and video more easily, a lot of the transitions are unlocked.
    pinnacle studio is a video, not a photo application
  3. Techno Freak
    Techno Freak
    Aug 24, 2003
    312
    16
    North-East
    So, would you say for a beginner in video editing that the bundled SE version would be sufficient? Or is it too stripped out of features to be worthwhile using?
    Cheers....
  4. Roy Mallard
    Roy Mallard
    I'd start using it and see how you get on, I reckon it'd do what 9 folk out of 10 want. If you wanted something more I'd spend a bit more money and buy Adobe Premiere Elements.
  5. Techno Freak
    Techno Freak
    Aug 24, 2003
    312
    16
    North-East
    Thanks Roy.
